wbwood
Aug 29, 2017Explorer
Coax cable
What's the best outdoor cable to use. Apparently the last couple of cables I have bought were not that great as the ends ended up breaking after several uses. I don't think the quality of the wire was...
1995brave wrote:
Push on connector
Used these for my cable to connect RV to campground coax. Quick on and off and lasts a long time.
j-d wrote:
If you're "rollin' yer own" connector installations, I'll pass a remark by Chris Bryant along:
Have a Cable Stripper that does NOT Ring or Ding the plating on the center conductor. That solid strand in the middle. Chris says the signal actually travels on the surface of that conductor, and it loses signal if damaged.
