What's the best outdoor cable to use. Apparently the last couple of cables I have bought were not that great as the ends ended up breaking after several uses. I don't think the quality of the wire was...
I have compression fittings on RG6 coax that has been out in the weather for at least 10 years with no problems to date. The fittings were installed by the local cable company at our getaway cottage, and have since been re-purposed for OTA antenna and satellite dish use. The compression fittings I've installed for outside coax use on our motorhome have also been fine, although not in use as long.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
