hershey
11 years agoExplorer
Coax connectors
We fulltime so we move around a lot. My satellite dish is tripod mount. I've tried the push on connectors to facilitate the connecting process and frankly, they just wear out too quickly and of cour...
wa8yxm wrote:I'm not sure where you dug this up but it's simply ridiculous and incorrect unless its 1958.
---snip--- Medium size coaxial
connectors with bayonet lock. 50 ohm impedance for applications up to 4 GHz and 75 ohm
impedance up to 2 GHz.
75 OHM SERIES
Within the internationally standardized BNC mating face dimensions, a perfect 75 ohm
characteristic impedance cannot be realized. However, at frequencies up to 1000 MHz, the
small impedance deviation is negligible for practical applications. Connex true
75 ohm connectors with a typical VSWR reading of 1.06:1 at 2000 MHz are identified by
an asterisk following the part number.
---snip---
