tarnold's avatar
tarnold
Cold tire pressure vs hot
Trying to set a tpms system. How much should a 225-75-16 tire pressure rise from 60psi cold to ?hot?, assuming outside temp of 70*. On the tpms you set for cold pressure. It will alarm at 15% . I wanted to alarm at a recognized 55psi. So if I set to say 63psi then it falls 15%, that would be around 55psi, or close enough. BUT coming from the tire store today it alarmed as high pressure and showed 73psi as the tire warmed up. Best I can explain it.
  • On my TST system, the defaults were minus 10% and plus 20%. For my rear tires , cold pressure 80 psi. The low alarm would go at 72 psi and high pressure at 96psi.
    I changed the high pressure alarm to about 104, because of driving in 100f temps. The side in the sun were just over 100psi, but the shady side stayed around 95 , 96 psi
    The high temperature alarm was defaulted to 160f. My tires were close to alarming that day as well. That temperature did agree with my infrared temp, I also checked a couple of parked trucks and there temps ranged from 170-180 on the driving sunny side.
    I’m much more concerned about low pressure than the highs, so I reset the low pressure alarm to 75 psi. Also the appropriate change for the front axle where I run 65 psi
    Ken
  • A good rule of thumb which I use is that for each 10 deg F rise in temperature, the tire pressure will rise 1 psi.
  • You should factor in what summer temps are going to do to the pressure. I've seen my 11:22.5 go from 90 lbs to 122+
Having RV issues? Connect with others who have been in your shoes.24,193 PostsLatest Activity: Jan 26, 2025
