j09789
Dec 24, 2017Explorer
Truck tire pressure.
Recommended cold PSI is 60 front & 65 rear. They are Michelin 275/65/20 load range E on a 2017 F250 Power Stroke. Should I increase the pressure when towing my 39' toy hauler (Triton by Voltage)?
Cummins12V98 wrote:slapshot12 wrote:
When towing, I always inflate the truck tires to 80 to get max capacity. When not towing, the recommended pressures are fine. Same thing with trailer tires, they are always inflated to max rated psi. Low pressure creates heat, which will destroy a tire sooner or later.
I advise doing a bit of research.
austinjenna wrote:Are you towing 365 or seasonal?
I am just a weekend camper, otherwise the truck is my daily driver.
rhagfo wrote:Cummins12V98 wrote:austinjenna wrote:
I also just run at max PSI all the time, towing or not.
WHY???
Ron, do you think they would notice the better grip on wet, snowy, or icy roads if they lowered the pressure to 45 psi, or DRW to 35????
I always like those the complain about poor snow traction with DRW, but run them like rocks at 80 psi??:h
WHY???
ChuckSteed wrote:
I’ve owned many trucks and autos over the last several decades.. I’ve never seen 100K on any set of tires no matter what brand... I am sorry but I don’t buy into 100K on tire mileage..
And if you are towing a fifth wheel I’d bet getting 50K would be about the maximum you’d ever be able to see, and have any safe level of tread depth left..
