Itinerant1
Sep 21, 2020Explorer
Depending on your heat duct maybe you can tap into it. Mine ended right above the batteries in the front compartment. I'll block the vent in the bedroom where this section is located so the air is forced down the pipe. There are 2 other vents in the bedroom/ bathroom so no lose in heat.
If we're running the furnace to heat the 5th wheel why not use some of it for the batteries.
Just to give you an idea. ;)
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
