Dennis12's avatar
Dennis12
Cold weather refrigerater
This may answer someones questions about your fridge.
Had a friend of mine take his motor home out as to load it for a trip. He noticed that the fridge would not cool. He tried gas and the electric. Nothing. He called a tech and the tech told him that the circuit board was out of it. He went to Campers World and purchased a new board. Installed it and it still would not work. I didn't know it nor did he, the fridge will not work below 20 degrees. He heated the motor home up and everything worked fine. If you look in the outside compartment at the fridge you will see a receptacle. that was put there so that you can plug in a 100 watt light bulb in the compartment in cold weather to make the fridge run below 20 degrees
Having RV issues? Connect with others who have been in your shoes.24,349 PostsLatest Activity: Jan 16, 2026
