j-d
Aug 05, 2015Explorer II
You gave it a Spin...
Did it spin freely or did it seem like you got it "unstuck?"
If it moves freely takes what I'll call a fast spin to pick up and run, then good chance it's a run capacitor. Probably 7.5-MFD at 370 or 440 VAC.
If it felt sticky, you may be able to oil the bearings with Turbine Oil. The bearing on the fan end of the motor will probably be the sticky one. I had this happen, sticky bearing on fan end of shaft. Even taking the motor apart and crocus clothing the bearing, it'd stick again. Ended up with a new motor, about $100 on Amazon.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 14, 2026
