PamfromVA's avatar
PamfromVA
Coleman 15000 Btu Heat Pump Upper Unit - White - 48004-876
Has anyone had any problems with the subject A/C-heatpump? Our camper came with one installed. Last April we noticed it was not blowing cold air and since it was out of warrenty we replaced it. Spent two weeks in Florida in 2013 and two weeks in Georgia this past summer and A/C was working great. Went out there last weekend and it is once again blowing warm air. The camper has not moved since we returned from vacation at the end of June. I contacted the manufacturer and have to take it to a service center for diagnostics since it is still under warrenty. I'm thinking about replacing it with a regular A/C (no heat pump) and see if we have better luck since replacing the A/C every two years doesn't seem normal.
  • I have one but only for about 2 months. No issues though, works fine.
  • I would take it in for that inspection to find out why its not working, along with the first unit you replaced if you still have it, but would have in my mind strike 2 do I want to go for strike 3 & be out.
    Might just be something simple keeping it from cooling, like the thermostat on the wall.
    Neil
Having RV issues? Connect with others who have been in your shoes.24,349 PostsLatest Activity: Jan 16, 2026
