sgossman's avatar
sgossman
Coleman 7335(?) Series Compressor Suddenly Stopped
I started using this AC unit after about 2 years of no use. It started up great with no problems and was kicking out cold air great for about 3 days until the compressor just stopped in the middle of cooling.
I thought at first it was because it reached the target temperature but it was too warm in the room for that. No matter what settings or how low I set it I can't get the compressor to start again.
The fan works fine and I already checked all the capacitors and they are working (holding charges) as well. The fuse in the thermostat appears intact and the unit is not tripping any breakers.
I'm kind of stumped as to what else it could be. Only real suspect I have left is the start relay and apparently the exact type isn't around and I need to use some sort of replacement model I'm not sure of. Perhaps it could be one of the boards but I'm not entirely sure how to test those or what levels I would want. The only maintenance manual I've seen seems to require a specialized device to test various aspects of the unit.
I believe its part of the 7335 series but the model number has since worn away. Another number is 6799A381.
Having RV issues? Connect with others who have been in your shoes.24,337 PostsLatest Activity: Nov 21, 2025
