mlj427's avatar
mlj427
Coleman AC freezing up
I have a 2013 Coachman with 2 Coleman 15k AC units. They were running fine with the fans on high yesterday and last night I came in today at noon outside temp around 90 it was 85 inside and both ACs running both were frozen. I turned them over to fan only and checked the filters and even used my phone to look inside the duct work to be sure it was clear. No problems found. Any idea why both would freeze up on a hot day? Definitely ruined the weekend.
Any help would be appreciated.
Thanks
Mike
  • I will be going down one day this week to vacuum the coil, pull the inside trim and make sure the baffles that keep the cold air away from the return air are in place and will check the freeze sensor location.
  • Best to buy an evaporator cleaner (most box stores), put old towels, etc under the duct so you don't get water in the interior and clean the evaporator and condenser from the roof.
  • Talked to the dealer service guy and Coleman’s service dept and they both think that the baffles between the return and output is letting the cold air leak into the return. So I will pull the lower shroud and seal any leaks then clean the coil. I will see how it goes.
    Thanks
    Thanks
    Get and use the FOIL CHROME AC tape.,. DO NOT use duct tape. I was going to mention making sure the air box is sealed correctly. One thing tho, your Freeze Thermister wire has debris all over it. That shows your Filter is not installed correctly or it is worn out. The only place dirt can come from is the interior of your RV and the filters stop that. At least most of it. Doug
  • Good point here. When I switched out my 13,500 btu for the current 15,000 it seemed it just didn't cool right. I was disappointed.
    I removed the cover inside the camper, took out the air filter and exposed everything and studied it out. The cardboard divider between the intake side and the output side was just hanging and had gaps allowing the intake to suck the out take air before it even had a chance to blow into the ducts or even the center blast.
    I used tape for aluminum stove pipe - extremely strong stuff and no second chances with it - touch it anywhere and it don't move again. It's silver color, extremely resilient to heat and cold as it's designed to take heat from a furnace for a gas water heater exhaust. (High temperature).
    Anyway, I taped up all the cracks and holes and then the puppy worked fantastic!
    As stated above, it's possible your cold air is being recirculated in over and over and over again, never allowing warmer air over the coils, thus causing the freezing.
    I agree, check inside and make sure you have good separation between intake and output sides. Some tape goes a long way.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 18, 2025
