Ray_IN
Jun 12, 2017Explorer III
Here are the instructions for building your own 50A circuit tester, which is used prior to plugging in your MH.http://www.myrv.us/electric/Pg/tester_50amp.htm OR https://50amppowerpal.com/ is needed.
That tests for proper circuitry, it does not test for amp draw.
If you have a hard-wired EMS system it will not allow electricity into your MH breaker panel if the CG circuitry is incorrect, but it will permit low voltage into MH. To safeguard against low voltage, a Surge Guard is required: http://trci.net/products/surge-guard-rv
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 23, 2026
