Vegas1's avatar
Vegas1
Coleman roof top heat pump
My Coleman heat pump calls for 115 volts 60 hz. It does not mention anything about amperes. What is the minimum amps required to safely run it? Will I cause damage to the unit powering it with 115 volts ac?
  • No, but you may damage it if you can't get at least 108vac delivered when it's running.
    No wattage given? What's the model number?
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
