GDS-3950BH
Jan 02, 2020Explorer
NRALIFR wrote:
Thanks. That makes five now.
I think at this point, it is incumbent on the naysayers to prove their claim that a garbage disposal cannot be used to pump sewage uphill. I’ve never used one like that, but I’ve replaced several, and played with a few enough to know that the water doesn’t just “fall” out of the disposer thanks to gravity. It’s under pressure.
Otherwise, I trust that said naysayers humility will at least allow an admission that their claims should be afforded the same credentials as they afford other interweb based claims; they don’t mean squat. Possibly even less than that.
Diddly squat.
Diddly squat, and whoopdeedoo.
Perhaps you can explain why by IPC, when your drain exits a wall the invert needs to be below the weir elevation of the trap exiting a disposer? Typical forum nonsense, and you have more BS than a cow pasture.
Done with this mental masturbation, happy new year
