mikestock's avatar
mikestock
Commercial macerator or homemade from garbage disposer
I am looking to get a macerator and looking for recommendations.
One reason I am looking at a homemade is that it, to me, would be handier to have a 120 vac model than to have one wired to my batteries, located on the other side of my coach. I also expect to get a little more power from a 1/3 hp ac motor than from the 12 vdc motor.
The actual total cost of the homemade would be a little cheaper, but not significantly. Storage space required would not be a factor for me.
I am leaning toward the homemade model, at this point. It is claimed that it would pump waste 100 feet with about a 7-foot lift in elevation through a 3/4" hose. That is much more than I ever expect to need.
Primarily, the reason for the macerator is to allow me park my motorhome backward at one of my favorite spots, with the windshield facing a river. I need to pump about 35 feet to accomplish this.
  • This guy built a garbage disposal macerator a few years back, and says it works fine. If you read through the comments, he and at least one other guy claim that they work great, and are pumping over 100’ distance and at least 4’ rise to their septic tanks.
    DIY RV Macerator Pump
  • Your average garbage disposal operates via gravity...simply grinding the solids that pass thru via gravity.
    Unless you are thinking of something different, I don't think it will work.
    PS: Running a 12v circuit to the other side of the rig, isn't too hard, so why mess with DIY when you can get a unit that is designed to do the job.
  • Bought a Flojet Portable Macerator/pump back in 2008
    Use it to pump waste tanks when parked at sisters/friends places
    Sisters is a 75' run with a 2' incline to clean out
    Pumps groundup waste just fine.........and will do so when 120VAC is not available
  • A macerator is typically a poop grinder and pump all in one unit. Garbage disposal is a grinder and that is all.
  • A friend has a macerator on an Airstream. It is at ground level and the inlet is large diameter. I think their Airstreams has shower and bathroom sink plumbed through the black tank to provide plenty a liquids. Not sure if that is a common practice.
  • For those that use macerators, is there ever an issue of the black tank not enptying well? I always thought it was important to have plenty of water in the tank so the velocity of it going out the drain would carry the solids with it. Even with the pump, it doesn't seem to me that the velocity of the exiting waste would be anywhere near that going out an open 3" valve and solids would be left behind.
Having RV issues? Connect with others who have been in your shoes.24,288 PostsLatest Activity: Jan 09, 2022
