romore
Jun 21, 2016Explorer II
It should start at 75 psi, less than 70 indicates issues. The cranking compression is low because it is equipped with an automatic compression release, a leak down test gives a much better indication of engine condition. A well equipped small engine shop should be able to do this for you.
