Chris_Bryant
May 12, 2013Explorer II
The most common failure is the freeze sensor, which will keep the compressor off. Depending on the model, you can jumper the freeze sensor terminals to test. The relay is not wired in a standard way as I remember. They feed power to the whole board through a top terminal.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
