BB_TX
Aug 15, 2016Nomad
I did the same as the OP. Although since my fridge is in a slide I have both a lower and upper side wall vent. Just a matter of reaching in thru the maze of tubes, wires and other obstructions and feeling your way thru the job. Less daunting than pulling the fridge out.
I cut a piece from a plastic mesh dish scrubber, compressed it as much as I could, and pushed it into the end of the new drain hose. Keeps bugs out while letting water drain. And while not a check valve, it does limit air flow.
