dougrainer
Aug 16, 2016Nomad
lawrosa wrote:dougrainer wrote:pyoung47 wrote:
"I would question the installation if you have room to reach up and replace it- specs call for a maximum of 1" clearance at the back."
I'm really not sure what you mean by "I would question the installation. . . . "
This isn't a science of rockets, it just drains water from the inside of the refrigerator.
Trust me, I did it.
What he means by installation is--IF you had access to reach up there without pulling the refer, the Installation is NOT CORRECT. If you install baffles to get that 1 inch clearance your refer will operate and cool much better. Doug
I have lots of clearance.. But I have the roof vent...
Refridge is as far back as it will go.
I have 8" or more
The REASON for that 1 inch is to force the cooling convection air THRU the upper Condensor fins. If you have more than I inch then your refer is NOT cooling to its potential. HAS NOTHING TO DO WITH THE ROOF VENT. Doug
