WILDEBILL308
May 13, 2014Explorer II
Most likely it is from a clogged drain. I would check my filters, if the filters get clogged they can create a low pressure and the water can't go out the drain.
I wouldn't bother with the attach bolts unless it leaks in the rain.
I had to smile as this post brought back the memories of laying on the roof trying to find the drain hole with a piece of coat hanger wire. I found the drain but the water flowed out so fast I couldn't get up in time it sure was cold.
Bill
Bill
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
