- chevyman2ExplorerX2 on the "Damp Rid" It sells for $5 for the small container or $10 for the big container at Wally in the camping section near automotive.
- wintersunExplorer IIDampRid is another solution and it words very well and is cheap. A starter kit and and two refills costs under $20. The water collects in the bottom of the container and you pour it out. When the packets are empty you put two more inside for another $3.50 and are good to go.
- NinerBikesExplorerOpen up vents and windows, until the moisture equalizes inside with out side, probably as well as temperatures. Warm air holds more moisture, get the warm moist air out of your trailer and the condensation problems go away.
Other option is don't drive to the south, especially to a state that's a big huge long jutting out peninsula surrounded by warm ocean currents and waters on 3 sides. Maybe head north, instead. - robsouthExplorer IIOpen your roof vents a tad and it will prevent condensation. Air flow (ventilation) is key as mentioned. This is true while parked as well.
- donn0128Explorer IIVentilation is the key.
- ksg5000Explorer IICondensation is result of cold meeting warm - usually takes place on window frames. Were you running heater in trailer when you were on road?
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
