RJsfishin
Nov 09, 2013Explorer
Dave H M wrote:
I appreciate all the input but still amd looking for ideas on the lash up to the electrical system, like where and how to tap in. :h
Ok, in the first place do you even know what you want to install ?
You said you want to install a receptacle, when in reality, a receptacle is a female electrical component that is live/hot. I doubt very seriously that is what you want. I'm not sure what a permanently mounted male plug is called, but is that what you want ?
But no matter how you connect the rear and front plug together, (excluding a 2 way switch) when you plug into either one, the other is going to be hot. Is that what you want ?
Ok, to answer the question, follow the existing cord, or permanently mounted plug to the junction box, and connect it there. If its closed in, cut a hole in it
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
