john_bet
Nov 09, 2013Explorer II
RJsfishin wrote:Ok I will give it a try. I would go to the nearest wholesale electric store and get what is call a distribution block. The come in single,double,triple pole. The have one or more openings on one side of the pole and one or more on the other. I would pull the wires of your existing cord from the c/b center and hook it to one of the hole on the multi side. Run new wire from the single side back to the c/b center. From your new inlet run new wire the a hole on the multi side again using a different hole. do this for all the different colored wires including neutral. Just make sure the same colors are opposite each other. Now you have two inlets exactly the same and no exposed hot parts with the lids closed. How ever if you are concerned with hot parts on one of the inlets the I suggest you use a transfer sw. in place of the distribution block. More questions just pm me.Dave H M wrote:
I appreciate all the input but still amd looking for ideas on the lash up to the electrical system, like where and how to tap in. :h
Ok, in the first place do you even know what you want to install ?
You said you want to install a receptacle, when in reality, a receptacle is a female electrical component that is live/hot. I doubt very seriously that is what you want. I'm not sure what a permanently mounted male plug is called, but is that what you want ?
But no matter how you connect the rear and front plug together, (excluding a 2 way switch) when you plug into either one, the other is going to be hot. Is that what you want ?
Ok, to answer the question, follow the existing cord, or permanently mounted plug to the junction box, and connect it there. If its closed in, cut a hole in it
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
