Harvard
Dec 02, 2013Explorer
Under the circumstances you would be ill advised to use the existing 50A setup for fear of destroying some appliances. Your surge protector has done a good job at protecting your equipment to date BUT I would run off the 12 VDC systems until this gets fixed. You could get a cheap 12VDC battery charger and run the charger off the 120VAC at the pedestal in the mean time.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
