- if the generator has a single output then yes generator input L1 & L2 will be bonded on the TS.
- DryCamper11ExplorerI'm interested in the electrical connection, not the mechanical plug/socket connection. The 50A ATS has two input hot leads at its gen input, L1 and L2. The 120v gen has only one hot lead at its output (which could be connected to multiple receptacles). Is that single gen hot lead normally electrically connected to short across both L1 and L2 at the ATS input?
- Depends on the genset.
Some gensets have a 120/120 neutral and ground twist lock setup.
Others have a 30 three wire 120 volt twist lock receptacle.
Having RV issues? Connect with others who have been in your shoes.24,361 PostsLatest Activity: Feb 16, 2026
