dougrainer
Dec 26, 2018Nomad
A 3000 watt Inverter is NOT DESIGNED to run 2 AC units. While the rating may indicate it, it is not designed to do that. I would NOT run ANY Roof AC on/thru an Inverter. NO NEED TOO, as the current draw will deplete the batteries in no time. The simplest way to determine HOW your AGS is wired is to go to the control module with the 20 pin quick connect. Check the AC tstat wires and see if they are used. If not used, then you do not have correct AC start. Doug
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
