Chris_Bryant
Dec 26, 2018Explorer II
The only easy way is to use a separate thermostat wired to the AGS- you *might* be able to hack a sensor on the outside blower, which is single speed (inside blower is 3 speed).
Or, you could buy an Onan EC-30W, which is designed to do that, but also uses a separate thermostat (built in to the device).
Or, you could swap the Atwood units for Dometic CCC2 controlled models, which have AGS signal output.
The only rigs I have seen with inverter run air conditioners were 24 volt inverters, with massive battery banks and oil cooled alternators to charge and run them, built on Prevost chassis.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
