Rmcgrath53's avatar
Rmcgrath53
connect comp to tri star 60 mppt controler with ethernet
Hello all. I tried calling Morningstar three times and all there guys are helping others. So here is what I have and perhaps someone can give me instructions on how to connect my laptop with the Ethernet cord to the charger. I have done that with no problem. My computer is wireless connected with a verizone card. I load up the msvue and search for device with error of ip address cant be found
Thanks
  • I new enough to set the system up and am trying to expand to the comp connect, I have an Ethernet cable going from my laptop to the controller I am hooked to the internet wirelessly from a internet card that can connect a couple computers. I load up msview and search for devices and an error pops up about cant connect to 192.168.1.237
    Thanks
    Thanks
    Since your laptop is wireless and the Mornistar is not, you will need to connect a ethernet cable from the controller to the laptop.
    The problem is you will need a SPECIALLY wired Ethernet cable which has the PAIRS of wires "switched". Standard Ethernet cables are wired straight through and your network hubs actually automatically switch the pairs for you. Hence the cable you need is a switched pair one or also known as a "crossover" cable.
    Once you have a switched pair cable you should be able to find the charger port address..
    Crossover cable
  • You need to use a crossover cable- not a standard ethernet cable if you are going direct from the computer to the tristar- otherwise a standard cable to a router would work.
  • Sorry no where near enough info to do anything but take a few guesses
    The controller does NOT have a DHCP server nor is it wireless
    Which means you will need to be on the very same subnet
    Did you connect via the RS232 serial connection and take a look at exactly what IP address you are trying to connect with?
    Most of the time they are very simple and easy to connect to
    Some more info will sure help to resolve your issue
Having RV issues? Connect with others who have been in your shoes.24,319 PostsLatest Activity: Sep 19, 2025
