BFL13
Apr 29, 2017Explorer II
I have used ordinary ANL fuses with no "holder" on the positive battery post with the pos wire's lug bolted to the other end of the ANL fuse, no problem. You don't need the "holder" if there is no strain on the fuse.
Actually, with a typical battery fuse, the short length of wire from the battery post to the fuse is unprotected, so having the fuse right at the post is better.
