hedge
Apr 29, 2017Explorer
The wire goes about two feet to a disconnect switch, then continues from the switch to circuit breakers for the inverter, converter, charge controller.
I may have thought of a way of using the fuse by adding a short cable, like 3" over to an open space between the batteries where I have some vertical room.
I just questioned if it was necessary as the OEM wiring just had one of those 30a auto-resetting circuit breakers and pretty sure it was at least two feet from the battery.
