hedgeExplorerApr 29, 2017Connect fuse directly to battery terminal?Can I connect a Mega style fuse directly to the battery terminal with the other end connected to the cable with a bolt? If it blows does the fuse stay in one piece? I installed new batteries and th...Show More
time2rollNomadApr 29, 201730 amp is easy.http://www.genuinedealz.com/maxi-fuse-inline-fuse-holder-w-6-awg-leads-up-to-60a
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 07, 2026
Related ContentQuick connect exterior shower hose doesn't connect.Nautilus P1 has leaking connectionsConnect Sink Directly to Portable Wastewater TankCan you use all terminals in parallel connection?Holding Tank Terminations
