donn0128
Aug 20, 2016Explorer II
exportman wrote:
yes. should be teflon not silicone. Regular hose washer is too big for the nut. So can I assume the obvious that 1) it does need a washer and 2)that I just need to find a smaller diameter washer?
Are you talking about the nut that the white hose screws to? A standard hose washer will fit in there. If your asking about the other side, inside the RV where the fitting screws to the PEX tubing, Thats another story.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
