myredracer
Aug 20, 2016Explorer II
trailrider wrote:
You need one of these to seal the pex nut to the brass fitting.
http://kcatalog.kellermarine.com/kcatalog/details.php?ProdClass=Plumbing&ITEM=5306435
^^^ This the correct washer. Should have come with the swivel fitting (that's the correct term). The city water inlet will have a standard 1/2" IPS thread that the swivel fitting threads onto. The photo below is a right angle swivel fitting and you can see the washer inside. The washer and swivel fitting should be available at most plumbing supply places.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
