exportman's avatar
exportman
connecting a city water flange
I am trying to connect a new city water flange in my motor home.I disconnected the old one, fed the new one in and tightened up the water line to it and it leaks at the connection. I wrapped some white silicon tape on the brass thread and screwed the fiberglass/plastic nut onto the threads. Even though I think it is tightened enough,it leaks at the connection point. Is there supposed to be a washer inside the nut to help make the seal? I'm a little nervous about over tightening the plastic nut to brass. Any ideas will be appreciated.
  • yes. should be teflon not silicone. Regular hose washer is too big for the nut. So can I assume the obvious that 1) it does need a washer and 2)that I just need to find a smaller diameter washer?
  • Actually is should be teflon tape.
    Did you forget the washer?
