SoundGuy
May 08, 2018Explorer
BFL13 wrote:
Use the diagram shown above. Note that you get more than twice the time at the same amps draw by having that second battery used together. So don't use them one at a time. (Peukert works for you!)
OTOH if the OP's original battery has been in use for awhile but he still wants the benefit of having two batteries available for dry camping then he should use them separately to avoid the old original from degrading the newly purchased battery. He can easily accomplish this by wiring the batteries with a dual battery disconnect switch such as the Blue Sea m-Series 6007.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 15, 2026
