BFL13
May 08, 2018Explorer II
When boondocking the converter is only able to be used with your generator. (no shore power!) So it is all solar, and your controller can meet the Trojan specs.
No need to change the converter if you don't use it anyway.
Even if the WFCO did do its 14.4v, the 35 amper isn't going to make much of a dent in a pair of 6s in a couple hours of gen time. You need to consider the big picture scenarios for when and where and for how long you camp to figure out what would be your best set-up for likely need for gen time and availability of enough sunshine.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 15, 2026
