MrWizard
Jun 30, 2015Moderator
All you need to do is turn off the breaker
Then check the voltage at the battery before and after
This will tell you if you turned off the converter,
tracing wires will tell you which one is the converter and which one is the bedroom outlets
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
