BFL13's avatar
BFL13
Explorer II
Apr 07, 2021
LFP on Shore Power with Inverter/charger?
An inverter/charger requires that you have a battery connected (or some 12v source) so it will supply any 12v to the RV. (Unlike a converter that will do 12v with no battery)
Some say not to float an LFP. If you choose not to float yours, what do you do when on shore power? You can't isolate the battery and run 12v off the charger in the inverter/charger since it would be dead.
You could just not enable the charger, and run 120v off shore power pass through---or can you? Does 120v pass-through happen with no 12v to the inverter/charger?--- And just cycle the LFP for your 12v, thus not floating it.
What do folks do in that situation?
Having RV issues? Connect with others who have been in your shoes.24,305 PostsLatest Activity: Aug 28, 2025
