FWC
Apr 21, 2021Explorer
time2roll wrote:
If the battery is cold and loses 30% of the capacity does the counting of AH still add up? If you know the battery is cold the voltage will still be dropping quick in the last 30%.
What ever system you have is but a guide. Keep your wits about you and all will be fine.
Yes the Ah counting still works even at low temperatures. The Ah used are still the Ah used, and these are not based on voltage. Better Ah counters (eg Victron) with a temperature sensor can adjust the available capacity based on temperature to provide accurate SOC as well.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
