jaycocreek
Apr 20, 2021Explorer II
BFL13 wrote:
FWC has shown how temperature changes the LFP voltage so much that you can't really use the voltage/SOC table if I understand him on that. I don't know if you can use a temp/voltage table and allow for the temp so you get "close enough".
The main thing you want to know while camping is whether you need to haul out the gen today or can it wait till tomorrow to do a recharge. You need your SOC now to decide that based on your planned usage between now and tomorrow. Solar is part of that decision of course.
"Close enough" is where the accuracy of the voltage reading matters. An AH counting monitor would be a better guide IMO, with your estimated adjusted for temp, low load, "resting" voltage as a rough cross-check.
So far I have found what StirCrazy said to be fairly accurate on voltage...Going on 9 days running my Engel fridge/freezer set at 35 degree's...And note the accuracy of the dumb voltage meter..LOL
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
