FWC
Apr 20, 2021Explorer
Coulomb counters/Ah meters work very well (when configured properly), and can easily track the battery SOC to 10% or so, which is plenty accurate for RV use. I am not sure why this is causing so much concern.
If you know the temperature of your LiFePO4 batteries, and the loads, you can probably get an estimate within 20% - 40% using voltage, but it is much more complicated than just glancing at your Ah meter.
I know folks like to fuss over their power systems (it is a hobby unto itself), but the point of a well configured system is the you don't need to be constantly thinking about it, it just does it't thing in the background. If you are running a decent size battery system of any chemistry, and Ah meter seems like a no-brainer, you can glance at it every once in while to make sure everything is OK, no need for tables, maths etc.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
