- myredracerExplorer IIThat's too bad. It works in the case of 30 amp services.
Chris Bryant wrote:
myredracer wrote:
If you have two 50 amp shore power cords, a 50 amp 4-prong generator adapter can be used to connect the two cords together.
That's a different twist lock configuration- I don't know the NEMA number off the top of my head, but the RV inlet has 3 blades plus the shell as a ground. - Chris_BryantExplorer II
That's a different twist lock configuration- I don't know the NEMA number off the top of my head, but the RV inlet has 3 blades plus the shell as a ground. - myredracerExplorer IIIf you have two 50 amp shore power cords, a 50 amp 4-prong generator adapter can be used to connect the two cords together. We have a 30 amp generator adapater that we use to join two 30 amp detachable shore power cords together when we need over 25'. We always carry a spare 30 amp power cord everywhere in case one gets damaged or stolen.
- bshpilotExplorerI built my own 75 foot 50A cord (to reach the outlet at my Father In Laws, when were on the curb) and i use it in our storage bay so i don't have to roll up the cords every time we go out.
If you want to build your own expect to pay 4 bucks a foot for RAW 50 amp cord, in a flexible (SO/SOO) jacket with 6 ga.3 conductor - 8 ga 1 conductor (commonly referred to as 6/3-8/1).
You can buy the plug ends from camping world (and other places) - Power Grip Plug
OR you can buy a 30 foot 50A Extension Cord from camping world (and others) for 100-150 bucks
google is showing some results of 100 foot 50A (generator) extension cords for 300 bucks, but you'd have to adapt or change the ends. - LarryJMExplorer II
Popsie wrote:
IIRC, HUD limits 50 amp power cord connections to a maximum of 36 and a half feet in length.
You would be very unlikely to have a HUD inspector check you hookup, but in the event of a fire, etc. damaging multiple units, a code violation noted by a fire inspector could end up with you found to be responsible.
With RVs and campgrounds I can't envision that ever being possible and even if it were I seriously doubt this would fall under any kind of code enforcement to start with. I sure would not worry about this scenario.
Now you might ruin one of your cords or the pedestal from burning up a connection, but that is a whole other issue.
Larry - BumpyroadExplorer
wa8yxm wrote:
I would recommend this...
Cut the cord (one of them) oh about 18-24 inches from the Marinco outlet.
Install a 50 amp female cord end (outlet) as others have suggested.
On the pigtail you just made you can install either a 50 amp plug or a 30 amp plug (This may take some doing) with BOTH Sides (Black and red, or black and black depending on the cord) to the copper screw. White to the slivery screw and we all know where green goes.
excellent suggestion. that is what I did with a 30 amp marinco fitting with a 20 amp plug so I could run a standard extension cord to the RV.
bumpy - wa8yxmExplorer IIII would recommend this...
On the pigtail you just made you can install either a 50 amp plug or a 30 amp plug (This may take some doing) with BOTH Sides (Black and red, or black and black depending on the cord) to the copper screw. White to the slivery screw and we all know where green goes. - PopsieExplorerIIRC, HUD limits 50 amp power cord connections to a maximum of 36 and a half feet in length.
You would be very unlikely to have a HUD inspector check you hookup, but in the event of a fire, etc. damaging multiple units, a code violation noted by a fire inspector could end up with you found to be responsible. - Chris_BryantExplorer III doubt you have to cut- those 50 amp twist locks are not molded- they are serviceable, and expensive.
I highly recomend this Progressive Industries connector as the replacement. - LowcountrydupreExplorerThanks. I will cut and replace.
Having RV issues? Connect with others who have been in your shoes.24,322 PostsLatest Activity: Oct 07, 2025
