RJsfishin
Mar 21, 2016Explorer
I'd say you're fixing it.
Did you know that if you keep a fresh water tank completely full at all times, that won't happen ? Unless of course you take on bad water.
If freezing is a problem, then that method don't work so good.
In warm/hot weather, the worst thing you can do is drain the tank when not using it. And the problem comes from the 1/2" of water that doesn't get drained.
During the camping season, fill the tank when you get home, instead of draining it, like most do.
