bighatnohorse's avatar
bighatnohorse
Explorer II
Mar 21, 2016
Contaminated fresh water tank.
Yesterday I poured a clear glass of water from the fresh water tank.
When held up to the light I could see a lot of particulate matter floating around in it.
It looked much like a snow-globe but not nearly as thick.
Pretty gross!
So I drained the fresh water tank, refilled and treated treated bleach water.
Ran the water pump to fill lines with treated water.
Drained tank again.
Refilled with bleach treated water and let sit overnight.
Currently draining the tank.
(Note: the camper is two years old - bought used three months ago by us. We've been drinking the water! First time in ten years of RV camping.)
So, question. . .has this happened to anyone?
What did you do to correct the problem?
What were your results?
  • Make sure you have a screen filter on the pump inlet. I use a refrigerator filter on a special drinking water filter that's rated at .05 microns. I had to look hard at the specs to find one that filtered particles that same. It claims to take out "cryptosporidium parvum" and other similar dangerous organisms. Change is at least yearly and every 6 months of you use it a lot. It also makes the water taste better.
  • Magnesium and lime deposits can accumulate and flake (shed) off plastic. I deal with this all the time down here (like yesterday for example) minerals cake on metal but not on plastic. I dump in a strong mix of white vinegar - let it sit for days - drain then refill with baking soda mixture and let that sit then drain. The amount of material flushed out is an eye-opener for sure.
  • When you were doing your bleach treatments, did you also run the bleached water through all the plumbing? If not, you should have. That's my spring routine every year. Flush the antifreeze, then bleach the tanks, and plumbing, let sit over night, drain and flush. good to go for the season.
  • Yes, I ran the bleach treated water multiple times through the system lines.
    The vinegar treatment is a good idea.
    How much though (to treat a 45 gallon tank)?
Having RV issues? Connect with others who have been in your shoes.24,191 PostsLatest Activity: Jan 19, 2025
