bighatnohorse's avatar
bighatnohorse
Explorer II
Mar 21, 2016
Contaminated fresh water tank.
Yesterday I poured a clear glass of water from the fresh water tank.
When held up to the light I could see a lot of particulate matter floating around in it.
It looked much like a snow-globe but not nearly as thick.
Pretty gross!
So I drained the fresh water tank, refilled and treated treated bleach water.
Ran the water pump to fill lines with treated water.
Drained tank again.
Refilled with bleach treated water and let sit overnight.
Currently draining the tank.
(Note: the camper is two years old - bought used three months ago by us. We've been drinking the water! First time in ten years of RV camping.)
So, question. . .has this happened to anyone?
What did you do to correct the problem?
What were your results?
  • I believe cave creek is in Az. Normal white stuff we flush from our water heater and same stuff that makes our white truck whiter after washing the truck.
    I might be wrong.
    chevman
  • Sounds like tanks never sanitized and cleaned. Your on the right track. We personally don't drink the tank water though.
  • Never had this problem. I would have treated as you did. I flush my tank once a year. Might check the vent screen on the fill cap mount. What color were the particles? Far as I know no one makes a locking fresh water cap so anything is possible. Happy Trails
  • I'd say you're fixing it.
    Did you know that if you keep a fresh water tank completely full at all times, that won't happen ? Unless of course you take on bad water.
    If freezing is a problem, then that method don't work so good.
    In warm/hot weather, the worst thing you can do is drain the tank when not using it. And the problem comes from the 1/2" of water that doesn't get drained.
    During the camping season, fill the tank when you get home, instead of draining it, like most do.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 16, 2025
