Almot
May 23, 2021Explorer III
time2roll wrote:
Why not just charge to 14 volts and let it float at 13.3?
Bulk restart at 13.1 is fine.
What are you expecting from the charging?
I can't charge it to 14 anymore, it won't restart Bulk. With battery resting at 13.2 controller starts with Float - which I set to 12.9. It did Bulk at the beginning of the experiment but not anymore. There wasn't much charging done here, 11A Bulk lasted a few minutes before I disconnected it. Battery is now at the same point where it was.
13.2 (more likely will settle at 13.1 if given some time) = 95% SOC. I don't expect much from charging at this point, but controller should at least try :). Maybe a few amps load will kick it into action, by lowering the voltage. Tomorrow.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
