StirCrazy
May 24, 2021Moderator
Almot wrote:
More news.
Raised Float to 13.8, also raised Boost Reconnect - don't remember the value because Epever software froze on the laptop. Upon restarting the software it became unruly, stopped recognizing the "station" (in other words, custom profile including data of the controller and solar array). I deleted the "station" and it's now refusing to add a new "station" and configure Port COM - Windows seems to dislike this software.
Whatever settings are in the custom profile, are buried in the controller memory for good. I can't communicate with controller, can't see or change custom profile.
Meanwhile controller itself works, quietly doing Boost at 10A, as I can see on its built-in display. Only I don't remember the latest settings and can't be sure they are still what I set.
Will try and return Epever and get Renogy Rover Li, it can't be much worse. Rover also requires a laptop and software for custom profile BUT at least it has a preset Li profile accessible (though not modifiable) directly through controller interface.
I have the renogy rover, all it requires is the bluetooth modual and the app and you can set it up how you want it with your cell phone. you just go to user definded battery type if you dont like the settings they have for Li and pick the value for each setting.
Steve
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
