- camperdaveExplorer
Bill.Satellite wrote:
Your gas generator has a 90-100 gallon tank of fuel to run off of allowing for few concerns about needing to refuel often.
Haven't seen many fivers with a 100 gallon fuel tank! :B - JimK-NYExplorer IINot only is propane expensive and bulky, but it is often hard to find. In my area the refueling stations have closed. There are plenty of exchange places but there are some issues. First the tanks are only filled to 15 instead of 20 pounds. I don't understand why except that this makes more money for the exchanges. Next the exchange tanks are often in bad condition, years and years out of date and do not show re-certification. You will not be able to get one of these tanks refilled.
- midnightsadieExplorer III run a few BOATS .just add sea foam to your tank run gen for a bit ,then forget it, some of my motors sit over a year and take off and run just fine. I do like the fuel shut off valve idea think thats a very good idea.
- Bill_SatelliteExplorer III am sorry to be another offering no information about your conversion, but I had a propane powered generator and it was a terrible mistake to have not put in a generator that ran on the same fuel source as the coach. Your gas generator has a 90-100 gallon tank of fuel to run off of allowing for few concerns about needing to refuel often. Should you change to propane you are also going to need to find a location to mount a 100# propane tank as you will burn through propane pretty quickly. On a very hot weekend in Virgina we were dry camping and the generator had to run 24 hours a day and we had to refuel fuel before the weekend was over. That would never have been an issue if I had been using my 100 gallon fuel tank. Propane is also generally more expensive than gas and it derates your genset by about 500 points (5000 would not be rated 4500).
- joebedfordNomad IIIWhen we bought our new toy hauler, second on the list of must haves after tri-axle was gasoline generator.
- romoreExplorer IIAdd Sta-Bil or a similar product to the gas and run the generator long enough to get it to the carb.
- MrWizardModeratorno info, because converting a built in gasoline onan
is a Very Rare thing
people usually convert portable generators
or maybe a stick house emg backup generator
BTW we had a Dp with LP onan, it was a liquid feed system
with a vapor/converter at the genny, needs a special LP tank
diy conversion kits for gas to LP use vapor systems and standard bottles, - johntankExplorerSince I have not gotten any info on the conversion I will not be checking in for some time, maybe several days.
Thanks - JaxDadExplorer IIIIf the Onan is in a 5’er it must then have its own fuel tank. It would be pretty easy to dose it up with SeaFoam then compared to a m/h where the fuel supply is the chassis tank.
Seems a bunch easier to just prevent the gumming up in the first place. - Dusty_RExplorerOn our '01 Itasca 24' mh I installed a switch on the fuel pump, and when I knew that we were not going to use the generator for a while I would turn the fuel pump off and let the generator run out of gas. That worked fine. Never had a problem with gummed up carb.
Dusty
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Mar 27, 2025
