- joebedfordNomad II
johntank wrote:
You're welcome. Bibi.
Moderator please lock or delet this thread as I have not gotten any real useful answers.
Thank You
johntank - JaxDadExplorer III
Thank You
johntank
It that’s your thoughts why did you even start here?
There’s plenty of online info, Google IS your friend. It’s dead simple, you need a vapourizer, regulator, tank(s), lines and some form of carb adapter plate, or a new carb altogether.
The chances of finding someone who’s done this anywhere is slim, on a single forum? Buy a PowerBall ticket, I think the odds are better.
Realistically however, unless you remove the fuel tank and replace it with a ASME type permanent tank you’re going to stuck with 20 or 30 pounders for a fuel source, read ‘very expensive’. - philhExplorer IIIPure gas is good
Aviation gas is better - fj12ryderExplorer IIIYou're welcome, come back anytime.
- johntankExplorerModerator please lock or delet this thread as I have not gotten any real useful answers.
Thank You
johntank - joebedfordNomad IIMy 5er has two gas tanks: 20 gallons for the generator and 30 gallons for the toys. Of course the 30 gallons can easily be pumped into the generator tank.
Bill.Satellite wrote:
MrWizard wrote:
What ever the capacity of the existing tank, it is there
And will give more runtime than the same amount of propane which will have to be carried in 20# or 30# bottles
Even 20 gallons of gas will equal 22 gallons or more of propane, which will be at least 5 20# bottles
^^^^^^^^^This^^^^^^^^^
If it's a factory installed gas generator you must also assume that it is attached to a vehicle with uses gas as a power source. Speculating that it's a 5th wheel with a gas powered 4000W generator seems to be a great leap to me. However, I know very little about how 5th wheel generators are powered.
How is it “speculating” or a “great leap” when the OP said that’s the case? - Bill_SatelliteExplorer II
If it's a factory installed gas generator you must also assume that it is attached to a vehicle with uses gas as a power source. Speculating that it's a 5th wheel with a gas powered 4000W generator seems to be a great leap to me. However, I know very little about how 5th wheel generators are powered. - MrWizardModeratorWhat ever the capacity of the existing tank, it is there
Even 20 gallons of gas will equal 22 gallons or more of propane, which will be at least 5 20# bottles - DrewEExplorer II
Your gas generator has a 90-100 gallon tank of fuel to run off of allowing for few concerns about needing to refuel often.
Haven't seen many fivers with a 100 gallon fuel tank! :B
Not only that, but many motorhomes (virtually all class C's, for instance) don't have a fuel tank that large. The standard Ford E series tanks are 55 gallons...which is still a lot of generator usage, particularly when compared to a dozen gallons or so of propane.
Some toy haulers do have a gasoline tank not only for a generator but also to fuel up one's toys. I don't think such tanks are anywhere near 100 gallons, though, in general.
Having RV issues? Connect with others who have been in your shoes.24,322 PostsLatest Activity: Jun 17, 2022
