westend
Jan 07, 2014Explorer
It sounds like the total load is where the problem is, not a single circuit so no need to redistribute or rewire the trailer. The OP states that when the AC is on and all of the entertainment devices in use, a breaker trips. By putting the AC on one phase in a 50 amp load center and putting those outlets most used on the other phase, the problems should cease. Configuring a 50 amp load center is all about balancing out loads.
I don't come near to using all of my 50 amps nor is there an imbalance on one leg. Just like residential wiring, distribution is the key.
Having RV issues? Connect with others who have been in your shoes.24,392 PostsLatest Activity: Jun 10, 2026
